georgieB
Flight distance : 33212 ft
Philippines
Ben Mason Posted at 11-2 01:27
Hi, Make sure your controller and drone firmware are updated to the latest and then calibrate the controller(while the drone is off)
Thanks Ben. This morning after the flight and was indoors when I started aircraft and RC, DJI app indicated flight database has an update of which it updated successfully. But that didn't stop the beeping. Subsequent powering on and off of both RC and AC showed no updates at all so I assume, both are updated. Also, went thru the Mavic manual but could not find how to calibrate the controller. If it is thru DJI assistant, I post my second problem which indicate that as of today I cannot my air to the windows app |
