Longest Flight
769 12 2018-11-6
MichaelDiggs
Flight distance : 151 ft
Only 13 minutes. This was the longest I could fly with my Pro. I recorded it, showing how little there were power lines and anykind of interferance. It was only 8100 feet or something close to that. Not even a mile out. DJI did repair my drone, replaced the main controller board and said it was tested fine. So I'm going to take off a the same location of this video and see if I can pass it. Also when flying over the lake about 200 feet or some obstable advoidance would instantly jump on and say there is something in front of me. Does this happen over water or something? Or could it be something to do with the faulty board they replaced? In the video you'll see the drone just stop, those were the times where thre advoidance came in and said there was something ahead and stopped to avoid a crash, but as you can see there is absolutely nothing in front of me the entire time. Well, here is the video. Also, it was a cloudy day, so I set my white balance on cloudy. Do I need filters for this camera? I heard Polarpro make a full set of filters for $149. Wonder if those are even worth buying. Anyway, do you think post processing could of made this video look any better? I know you may not be able to see it like I can, because it is streaming on youtube, but the original flying video does look really good.
2018-11-6
A CW
Flight distance : 13838848 ft
Good work!
2018-11-6
jacksonnai
Malaysia
Nice flight thanks for sharing
2018-11-7
jacksonnai
Malaysia
Would be really nice if you can enable playback on other websites, as it will be easier for the user to watch it
2018-11-7
Montfrooij
Flight distance : 2438094 ft
Nice work!
2018-11-7
S.D. Pilot
Flight distance : 10278435 ft
Nobody even answered your questions.
" So I'm going to take off a the same location of this video and see if I can pass it. Also when flying over the lake about 200 feet or some obstable advoidance would instantly jump on and say there is something in front of me. Does this happen over water or something? Or could it be something to do with the faulty board they replaced? In the video you'll see the drone just stop, those were the times where thre advoidance came in and said there was something ahead and stopped to avoid a crash, but as you can see there is absolutely nothing in front of me the entire time. Well, here is the video. Also, it was a cloudy day, so I set my white balance on cloudy. Do I need filters for this camera? I heard Polarpro make a full set of filters for $149."
1.) flying over the lake about 200 feet or some obstable advoidance would instantly jump on and say there is something in front of me. Does this happen over water or something?
I've noticed on a couple of previous flights different messages as well but nothing that interefere with the flights from what I recall. I fly over water all the time and that in itself doesn't become a problem where it would effect the drone.
2.) Or could it be something to do with the faulty board they replaced?
Strong possibility. Did you crash and have DJI replaced/fix damages ?
3.) Do I need filters for this camera? I heard Polarpro make a full set of filters for $149."
Strickly your preference. I had filters before but got rid of them because I usually render the raw footage then fix in post.
2018-11-7
Woe
Flight distance : 4129268 ft
Nice work.  flying at 200ft is a little low for distance flying. At 8100 is about 1.7 close to 1.8 miles out.
When out that distance height is your best friend. The sun sometimes trigger the OA
even with an ND filter on it. Next outing try for height along with distance.
2018-11-7
DJI Stephen
Super Moderator
Hi. Good day and thank you for sharing this great experience with us. Have a safe and happy flying always.
2018-11-7
Sky Carrier
Flight distance : 590102 ft
Nice video, thanks for sharing
2018-11-7
Zatx
Flight distance : 158166 ft
8,000 ft is way more than a mile out, it's nearly two miles. As another commenter mentioned, 200ft is very low for distant flight. At that height and range, the trees and ground are interfering with your signal. Ideally, you want line of sight for maximum range.
Do you need filters? No.
Are filters needed to keep the framerate in the cinematic effect range (1/50 for 24fps filming)? Absolutely.
2018-11-8
davidmartingraf
Flight distance : 84805085 ft
Nicely done - thanks again for sharing!
2018-11-8
Easy Ed
Flight distance : 41414 ft
2018-11-8
MichaelDiggs
Easy Ed Posted at 11-8 16:43
Well I received the "repaired" drone this week. I sent it to them for repair since I couldn't get any good distances with an area that just had trees and water. No power line, not even houses. I could only get 1.5 miles out, and this drone is advertised for 18km which is 11 miles. Seriously DJI, why would you even advertise that distance? Anyway, I took it out for a test flight and all I could get was 8000 feet, which is 1.5 miles. Now I'm not expecting 11 miles at all, not even half of what it is advertised but when flying over prestine conditions with just trees and some water and only being able to get  a tiny percentage of the advertised distance is pretty lame and really should be thrown under false advertising.  There must be A LOT of fine/small print all over about this drone. With the conditions I had,  I would hope to see maybe 3 miles would be nice. Not too much to ask for when it is advertised for 11 miles.
Ok, big question of the day. How would I get my flight data off the SD card? I'd like to reproduce the flight with all the flight data on the screen like I'm flying the drone. What's the easiest way to do that? I believe I read somewhere I need to export files somehow off my SD card  and then import them back into something else? And is everything played back through the DJI app on my phone or is there a way I can play it all back on my computer? Well, thanks for listening to me rant on and vent!
2018-11-11
