Mavic Air Controller Incessant Beeping
12
55936 44 2018-11-8
fans97241781
Flight distance : 2463015 ft
Romania
x2202 Posted at 2019-9-21 04:46
The real problem is purely technical. It is the electrical contacts of the joystics which pose problem. To make sure that is where the problem comes from, you have to operate these joystics in all directions BEFORE turning on the remote control. The beep beep should simply disappear..
I rotated and I moved joysticks in all directions and beeping stopped. Thanks a lot.
2020-9-24
sraj9
Flight distance : 715 ft
India
Bluehook Posted at 2-18 13:43
I experienced the same thing yesterday.
I hadn't flown the drone for many weeks. The RC is always stored on a shelf, uncovered.
THANKS SO MUCH. THIS ABSOLUTELY WORKED OUT FOR ME
2020-10-18
Eric Larmier
Climbnride58 Posted at 2019-4-23 12:49
Turn on drone, and controller. If the controller beeps continuously, press the button on the front of the drone for three seconds, or until you here a beep from the drone. Controller, and drone should then sync.
Worked perfect for me today, thanks!
2022-4-30
djiuser_svb6uB5mm30f
United Arab Emirates
Correct, thank you so much.
2023-1-21
Jorge Ramirez0
Mexico
Man, awesome quick fix! My problem started today, lucky i found your comment!
4-24 19:01
12
