hallmark007
Flight distance : 10017858 ft
It can’t be known what exactly occurred, it’s easy to see you had interference in your drone and compass problem, so the person with the most information is yourself, when you took off it looks like you were in some waste that is also some kind of car park, could you have been close to car before you took off could you have started drone close to your car, it looks like you picked up some magnetic interference and it showed when you were 30ft off the ground which is quite possible , if you watched the video I put up you will see what I’m talking about.
Your first reaction when you get this kind of interference is just land, but easier said than done, your aircraft was flying slow and not as others said very fast, but if it hasn’t happened to you before then confusion and panic can set in.
But for your experience dji have honoured your warranty and that’s great and hopefully your back in the air soon. |
