doubleJ
Flight distance : 2762 ft
If you copy/paste, it will change the date created as it's actually creating a different file.What you will find is that the date modified doesn't change (unless you actually modify the file).
So, two semi-useful options are to cut/paste the files or just use the date modified and understand that you'll have to subtract the length of the video from that time.
It would be best if DJI would change the filename structure to something based on the date/time that the file is created (YYYYMMDD-HHMMSS or similar).
Of course, pictures should contain a date taken attribute (too bad videos don't).
JJ
