Engage ATTI mode on the Spark
12
15147 75 2018-11-24
Daniella3d
DJI Stephen Posted at 11-25 10:32
You are much welcome. If you have any inquiries or concerns please feel free to post it here at DJI Forum. We are here to help and support you. Have a safe and happy flying always.
I do have an inquiry...why does DJI not offer us an option to switch to ATTI and back to GPS? it would prevent lots of fly away if people would be able to practice what happen in ATTI instead of just being there watching it fly away.
2018-12-24
Wolferl
Flight distance : 23793 ft
Austria
Daniella3d Posted at 12-24 04:33
Well, that's a thing called "marketing". You should buy the next better drone model :-)
BTW: you're now able to practice ATTI mode flying if you want....
Cheers,
Wolferl
2018-12-24
Albermen
Thanks mate! This helps a lot
2018-12-27
Daniella3d
Wolferl Posted at 12-24 05:54
How so? is there an official way to switch it to ATTI beside this solution?
2018-12-27
Wolferl
Austria
Daniella3d Posted at 12-27 16:08
No, unfortunately there is no "official" method, and there never will be for the Spark.
So we need to help ourselves....
Cheers,
Wolferl
2018-12-28
timtwomey
Flight distance : 2164206 ft
I made the parameter changes yesterday and tried it out today.  Wow!  The wind was barely noticeable at ground level.  I brought the Spark up to about 1.5m and let it hover.  Perfectly stable.  Flicked the switch to Sport (Atti) and it immediately started drifting away. I was able to control it for awhile, but it quickly got confusing.  I switched back to P-GPS to regain control. I repeated this sequence a few times.  And the Spark is like a little rocket in Atti mode.  I can see how people quickly lose the Spark after an encounter with Atti mode. I plan to spend a good amount of time practicing my Atti skills
Thanks very much Wolferi
2018-12-30
Daniella3d
Well, that did not work for me. I change to 1 and true but it does not retain those changes and when I open the new panel I don't see all those options, just the regular ones. Nice trying.
2018-12-30
Daniella3d
Ok it work if I don't close the panel. Interesting. Anyone tried it? does it really work and does the sport mode really put it into ATTI?
2018-12-30
Daniella3d
timtwomey Posted at 12-30 18:10
Good thing it is easy and quick to switch it back to GPS mode huh?
2018-12-30
Wolferl
Austria
Daniella3d Posted at 12-30 21:28
Hi Daniella3d,
Yes, DJI Assistant 1.2 debug mode must be enabled every time you want to use it.
So, you start DJI Assistant, set the two fields, close the right panel, connect your Spark, wait until it is recognized and then do your settings.
Yes, it does work
Cheers,
Wolferl
2018-12-31
Daniella3d
Wolferl Posted at 2018-12-31 02:24
Hi Daniella3d,
Well that's the problem, if I close the panel it does not retain the settings and when I click on the spark icon it does not show the developer options. If I want it to work, I do not close the panel after I make the change to 1 and true, I just click on the spark icon and that works.
For it to work, I must not close the panel.
2019-1-1
Alex B.
Flight distance : 21105262 ft
Where do you get the version of the DJI assistant that lets you modify the parameters? Please, I can’t find it anywhere
Flysafely
Alex
2019-1-1
Wolferl
Austria
Alex B. Posted at 1-1 21:54
Flysafely
Hi Alex,
If you open the video in YT, look at the video description. It's all there :-)
Link for WIndows and Mac: https://www.drones4.life/dji-assistant-2-download/
Cheers,
Wolferl
2019-1-2
Wolferl
Austria
Daniella3d Posted at 1-1 17:42
Hi Daniella,
Hm, that's intreaging. It does not behave like that here.
As soon as I enter the "1" and the "true" (both are needed!) and press Enter, I can close the panel, and it remembers the debug mode for this session.
Cheers,
Wolferl
2019-1-2
Daniella3d
It's very dangerous to fly in ATTI mode outside though, because if the RC disconnect then no luck, it's gone bye bye. I guess anyone using this option should do it at close range to avoid RC disconnecting. I am a bit afraid of that since mine disconnected from the RC at 15 feet distance. If I would have been in ATTI mode, it would have crashed for sure with no RC control. I would not fly ATTI mode out of sight.
2019-1-2
ped078
Flight distance : 565794 ft
Thank you so much! How did you find this out?
Thanks to you my Spark has had his chains cut and stabilisers thrown in the bin
PS Whats the difference/advantage of FCC over CE?
Ped
2019-1-2
Greg - TheHuski
Flight distance : 944308 ft
Daniella3d Posted at 2018-12-23 18:10
How far were you ? ''maximum distance reached''... ??
Max distance set at 480m...  but the app was showing well over 500+ m...  so hard to tell what was correct..
2019-1-3
Wolferl
Austria
ped078 Posted at 1-2 11:59
Hi Ped,
That was just out of courioity...I read somewhere here about the debug mode and tried it. Then came the idea :-)
FCC allows much more RF transmission power then CE.
Cheers,
Wolferl
2019-1-4
ped078
Wolferl Posted at 1-4 01:26
Hi Ped,
Just to confirm this trick works. I took mine out yesterday and wow...Why DJI don't make this a feature is crazy. It'll make better pilots as they will be more accustomed to flying in ATTI mode should a flyway occur. It finally puts you in control, you're not simply pointing the drone where you want it to go, you're FLYING it there which is sooo much better.
One thing to watch out for, it caught me out...when you let go of the sticks, the drone doesn't stop...it slowly decelerates but it has plenty of inertia, so you have to brake gently to bring it to a stop.
Thank you so much for this little hack Wolferl
2019-1-5
Daniella3d
ped078 Posted at 1-5 07:20
I am looking forward to try it. Does it have a way to stabilise it? like with my Hubsan X4 I have trims that I can use to balance it if it is drifting in one direction, I can compensate for it buy using the trim buttons. I guess flying in ATTI mode need that you calibrate the drone right before flying? Also since mine already disconnected from the RC at close range, I am a bit afraid of using ATTI mode since it would be drifting to oblivion and no return home.
2019-1-5
Wolferl
Austria
Daniella3d Posted at 1-5 08:43
Hi Daniella,
Unfortunately, the Spark R/C does not have any trimming devices. It wouldn't be of much help anyways because that kind of trimming against the wind is wrong as soon as you turn the aircraft.
Yes, before you try ATTI mode you should sort out the connection problem your bird has...
Cheers,
Wolferl
2019-1-6
Gator Don
Great information, thank you very much
2019-2-13
kRx md
Flight distance : 158914 ft
Philippines
This is a great video. I just need the nerve to pull the trigger to modify my spark.  I haven' t encountered the sudden switch to ATTI mode mid air out of nowhere. What i've encountered is just pushing the distance and getting disconnected and RTH luckily kicking in to bring the bird back home.
Thank you for this video.
2019-2-23
Wolferl
Austria
kRx md Posted at 2-23 09:53
You're welcome!
This "modification" can easily be reset to original. You won't void your Sparks warranty, so nothing to worry about. But please be careful when you do your first ATTI mode flights. Don't panic. Use a large open field with no obstacles. If you lose the birds attitude (will happen!), just switch back to normal mode. You can then even use RTH to get it back.
Cheers,
Wolferl
2019-2-23
andrewjkm
Grüss Gott, Wolfgang. Do you - or does anyone else - know where the AppFiles/main.js would be found on a Mac (OS 10)? I have DJI Assistant 1.1.2 installed, but can't find the js file anywhere. Vielen Dank!
2019-6-1
Wolferl
Austria
andrewjkm Posted at 6-1 13:00
Hi Andrew,
I'm sorry...maybe someone with a Mac on hand can check?
TIA,
Wolferl
2019-6-3
Flygmaskin
Flight distance : 70719 ft
Sweden
Hi Ped,
I’m really thankful for your curiosity! Great thing to know, and gives people a chance to practice their skills in flying without assistance from the various systems.
Thanks a lot!
Just to clarify, this was done on the latest firmware of the Spark?
And also, have you found anything else interesting that one can do in this developer program?
Highly unlikely, but it eould be great if we could could use the developer program to get Spark to read Galileo satellites, I understand that at least the hardware supports it..
Anyway, thank you again, vielen dank!
2019-8-18
Wolferl
Austria
Flygmaskin Posted at 8-18 22:19
Thanks a lot!
Hi Flygmaskin,
Yes, I did these experiments with the latest "1000" firmware in the Spark.
There is another thread that describes how to setup Expo on the sticks. Useful to make slower turns.
Cheers,
Wolferl
2019-8-19
sparkflier14
Flight distance : 194619 ft
Is this Something approved by DJI and/or won't void your warranty?
2020-2-18
Wolferl
Austria
sparkflier14 Posted at 2-18 17:47
Hi,
It is of course not officially approved by DJI
Since you can revert the settings back to factory default, you won't be having problems in terms of warranty.
Cheers,
Wolferl
2020-2-19
djiuser_KUm3lckFtCiT
Singapore
Hi,
I've tried and failed. I can see the atti pop up screen comes and go off but it doesn't switch. If I try to launch in atti mode, it will be in atti mode for few seconds and automatically switch over to GPS mode. What do you think might have gone wrong?
Need your advice, many thanks.
2021-3-5
Wolferl
djiuser_KUm3lckFtCiT Posted at 3-5 03:50
Hi,
Hi,
Does the text ATTI (yellow background) appear at the top of the screen, where usually the green P-GPS is shown?
Cheers,
Wolferl
2021-3-5
Singapore
Nope, if switch from GPS to atti. But the pop up screen from the left, will appear and go off.
If launch in Atti mode.. The top display bar will show atti for few seconds then automatically switch back to GPS mode again.
2021-3-5
Wolferl
djiuser_KUm3lckFtCiT Posted at 3-5 09:57
Hm, that's weird, definitely not right.
What firmware version are you using on the Spark and the R/C?
Cheers,
Wolferl
2021-3-6
Singapore
Wolferl Posted at 3-6 00:14
Hi,
Apologies on replying late.
Aircraft firmware: 01.00.1000
RC: 01.00.0600
My email is leongkh11@gmail.com
Communication should be more prompt.
Appreciate your helpfulness.
2021-3-6
Wolferl
djiuser_KUm3lckFtCiT Posted at 3-6 08:12
Hi,
I'm on a business trip right now, so I can't check anything right away.
Can you do a little video where we can see the remote sport switch and the phone screen when it happens? Also a screenshot how you setup the Spark (DJI Assistant) would be very helpful.
Cheers,
Wolferl
2021-3-6
12
