trooper1
Flight distance : 26611 ft
You're right: BVLOS is not just intervening terrain. We're going for a BVLOS waiver to fly the large, flat, sparsely populated valleys in NV, such as Clayton Valley; a large salt flat that has one of the largest lithium concentrations in NA. No need to get behind intervening terrain to fly miles beyond los. However, even tho our agency has the need to fly a lot of remote valleys, we still have need to fly in mountainous areas. With a loss of signal control, we couldn't switch out of auto mode and manually fly it, even if our VO called in an emergency downrange.
Flying BVLOS is going to require tech to bounce the control, like the USAF does it, exc without the satellites. Maybe VOs equipped with portable repeaters. I'll have to limit our mountain missions to one's where the pilot hikes ontop of a hill and has unbroken, but distance los to the desired target area. I'd like your opinion: do you think the FAA review team would approve us flying in a remote valley that is within a Military Operations Area, MoA? Southern Nv has huge MoAs; these are in addition to the Restricted airspaces, that we won't propose to fly in. At this point, I'm considering dropping the half dozen BVLOS candidate areas within MoAs. |
