JJBspark
Flight distance : 12225059 ft
Hi Alex,
Hard to tell why your MavicPro crashed, end of the flight just stops when it is still flying under control.
You had many disconnects, if its a full disconnect a RTH will start. Your first disconnect 44 seconds, because your drone is close to homepoint it will autoland.
(answer to your question, see the manual for how and when a RTH starts)Disconnects happend mutliple times. All pitch and roll data looks fine, so no rapid moves etc.
It looks as your drone was under control when connected.
What happend during connection loss is not written in the file, so cannot tell wich inputs you did on the RC.
My advice is always land after the first error, disconnect etc instead of continue flying.
Try to find out what causes the problem.
Hope the repairs will work out good for you.
After that many happy landings!
cheers
JJB
