I’m experiencing the same issue. Mines did not make that grinding noise when I first used it. Then the second time it started to make that noise and the gimbal wasn’t working properly. Kept saying “gimbal limit reached” and the device got really heated.
djiuser_6QfePJxOFuuU Posted at 12-12 19:45
It’s funny you mentioned that. I’m 99% sure mine didn’t make this noise when I first used it. Is your sound the same as in the video?
Hi thank you for bringing this query to us. Apologies for the confusion but this is a normal phenomenon. Have you received some errors on the app? Kindly reach us again if you have concerns. We're here to help you. Thank you.
fans5f25172a Posted at 12-13 13:06
Thanks DJI, seems to work fine otherwise. It’s just weird that we never had grinding sounds initially and it started out of no where.
Has anyone else got a new pocket with or without these sounds?
Yes, mine makes small clicking noises when the gimbal moves.
