GoMagic2
Hello,
this is what I got from the Lufthansa web site.
I plan to travel from Munich to the LAX.
I try to find the " UN Manual of Tests and Criteria’, Part III, Sub-section 38.3. "
As I understood dji should have a document for their Battery pack?
Did anybody find this document?
Specification
Non-spillable batteries (dry batteries, gel batteries) used for wheelchairs and other mobility aids.
Checked baggage: Yes
Carry-on baggage: No, except removable batteries
Carrier’s approval required: Yes (1)
Rules
- The battery must be securely attached to the wheelchair or mobility device.
- The battery terminals must be protected to prevent short circuits, e.g. by being enclosed within a battery container.
- Lithium-ion batteries must meet the requirements of the ‘UN Manual of Tests and Criteria’, Part III, Sub-section 38.3. Proof must be provided when booking or checking in at the airport, e.g. by a certificate from the manufacturer, or a personal written confirmation.
Batteries designed to be removed (e.g. in collapsible devices):
- The user must remove the battery.
- The battery must be protected from short circuits by insulating the terminals (e.g. by taping over exposed terminals).
- The batteries must be individually packed in a protective container provided by the passenger.
- The battery’s watt-hour rating must not exceed 300 Wh.
- A maximum of one spare battery not exceeding 300 Wh or two spare batteries each not exceeding 160 Wh may be carried.
- The battery must be carried as additional carry-on baggage.
The carriage of electronic personal transportation devices powered by lithium batteries (lithium-powered personal devices) is prohibited on board aircraft both in checked baggage and in carry-on baggage. This regulation applies regardless of the power capacity of the battery.
