sixthday
No. Without the adapter, you are out of luck. The USB port under the camera wont work, it will NOT let you activate or firmware update. Many previous posts already mentioned that. The only way you can activate it is to find a another adapter or find a iPhone (assuming you still have the iPhone adapter). Be aware, without the adapter, you still wont be able to do some setting because many can only be done through the phone. For example, if you want to shot with 4L/24p superfine, you are out of luck without the adapter because you wont be able to enter that mode through the camera |
