Lysak2003
Flight distance : 500052 ft
Ukraine
So do I!
Let's repeat all basic steps we do before taking off.
1. Check the propellers and their connection to the motors.
2. Remove gimbal protector before turning drone on (If you haven't one, you should buy it).
3. Turn on remote controller, connect the phone and run DJI Go 4. (You should turn Airplane mode on your phone. If someone calls and you accidently answer it definitely may cause Flyaway.)
4. Install drone on the flat solid clear spot and turn it on.
5. Check all messages in DJI GO. If it shows "Compass Interferentions", you should search another place to fly.
6. Remember that cold weather can forbid you to take off. In this case you should keep your battery near your body to save it warm.
7. Calibrate the compass. You should remove all metal things from your body. Keep phone on the distance from the drone. Follow the instructions.
8. Set up Return to Home point, RTH altitude, maximum distance and maximum altitude. Also you should turn on "RTH at current altitude".
9. Check the number of satellites and type of flying mode. If satellites are less than 8, it shows you ATTI mode. Be careful to fly in that mode when it windy. Also when connection is lost between drone and RC, drone doesn't do RTH in ATTI mode and Flyaway by wind.
10. Take off and hover. Check all messages. Check conditions of hovering drone. If it drift in arbitrary directions, jaw, rotate - something is wrong, land it immediately.
11. If it's all right then slowly increase altitude at about 10 metres without moving in any direction.
After that you can do your flying plan. |
