CruiseHabit
Flight distance : 93225 ft
In the event you find yourself elsewhere with only 220/240v here is a quick explanation:
The Osmo Pocket charges via USB, so really the question is do you have a USB power block that accepts 220/240 (the US uses 110/120). The great news is that most things manufactured in the past 5-10 years are dual voltage - they'll accept either. This is because we largely use switching power supplies rather than those using wire-wound transformers (in short, better tech). This technology is handy for manufacturers, as they now need fewer versions of products than in years past.
You'll need to look at labels though, as there are still some wire-wound transformers out there as well as things that are directly powered (thing, heat-generating gear like irons, coffee makers, etc) that are not dual voltage.
To use dual voltage gear, you'll still need an adapter for the plug, but not a power converter (which are larger, more expensive, and vary in capacity).
I show examples of the labeling you can look for on your devices at the below link. Please note I'm sharing as I have info relevant to the original question here - not trying to sell people an adapter (not exactly the ideal audience, I got bigger fish to fry). Further, Tanzania uses type G and D plugs - not the same as in Europe, so this adapter doesn't work - but again, the information is still relevant. One of the two plus used in Tanzania is the same used in the UK, so a UK adapter could be handy for you to have.
https://shop.cruisehabit.com/pro ... s-in-your-stateroom
I hope this helps clarify things - reach out with any questions!
