Gulfstream
Flight distance : 98996 ft
It's absolutely worth the investment. I actually bought the M2P w/Smart Controller before I really even knew much about it. But I did know that it would be better than most Android phone solutions. I did have a few issues initially, one with connectivity to the aircraft and the second with blowing back to the GO Fly Screen.
The second issue was because of my method of stick control and my fat thumbs. I tested this by moving my thumb over the top left of the screen [DJI] logo, and even without touching the screen but very close, the app popped back to the GoFly screen. I bought longer sticks, slight change my method, problem solved.
The connectivity issue took a little more research, but I did find a few things that seemed to have helped. Remove any cached maps, video/images, and third party apps such as Instagram. Do a Factory reset, and refresh the firmware via DJI Assistant 2 For Mavic. I'm on a Mac and it was a bit tricky, but I found out that you need Developer Options On, and USB Debug. Importantly DO NOT Change the mode to copy data etc. Leave it in the "default' selection - Top Button Copy Photos, and start the process. I would recommend that you shutdown anything else on your wireless network that is pulling at lot of bits (Netflix etc) until the process is over. Let Assistant 2 have the bulk of your bandwidth. I did have to restart the firmware process 3 times before I got a successful d/l.
After all of this, it was immediately noticeable on my flight yesterday that I had better connectivity [Zero Warnings] and AirData logs confirm that as well. So yes, I'm glad that I own the SC, it will make my life better. |
