Osmo Pocket Screen Wont Turn On!
25109 30 2019-1-11
djiuser_eT2LHK2KPEqr
I been having issues where the screen wont turn on at all with nothing attached etc.   From powered off to powered on the screen wont turn on. I have to play with it for hours then all off a sudden the screen will work again. Its almost like it thinks its hooked up to my phone so the display turns off.
I also updated to the latest firmware last night and same issues.... Any suggestions?
2019-1-11
DJI Paladin
Flight distance : 318 ft
Hi there, our apologies for the inconvenience. If it is convenient for you, kindly provide a short video of the issue for further check. You can upload it by using google-drive or Dropbox and provide the link here. Thanks for your support.
2019-1-11
DJI Paladin Posted at 1-11 08:49
Here you go! https://www.dropbox.com/s/lf76qrik0ydz6zz/IMG_9245.MOV?dl=0
2019-1-11
andyboyduk
Flight distance : 903576 ft
I had just the same issue in London yesterday, following several successful shots without a mobile device attached.  I turned OP on and off several times. Each time the gimbal startup motions were as normal but blank screen. In the end I pressed both buttons together to start-up. The screen came back to life. If it shows the same fault in future I I will try connecting my mobile phone to see what happens.
2019-3-16
JohnnieClark
I am having this same issue as of today. Has there been a fix for this?
2019-3-16
Syaz217
Flight distance : 136040 ft
Brunei
I'm having the same issue, the screen lights up but the logo won't show and the display remains black. It requires a few restarts to finally have the display show the normal screen.
2019-4-14
robomaniac
remove the SD card and try again.
2019-4-14
robomaniac
to be more precise, try to power ON osmo WITHOUT the SD card.
I had some weird issue where the camera would power ON then OFF and cycle like that until I stop it. It was a problem with corrupt SD card. Corrupted for the osmo but all other camera (gopro) had no problem. Files on SD cards where good.
https://www.youtube.com/watch?v=ALpIMB2k4jc
2019-4-14
robomaniac
and could you please try plug into your phone.
2019-4-14
Syaz217
Brunei
Tried it with and without the sd card, the built-in display won't turn on. Using the wireless module and plugging it to the phone works fine. Its updated to the latest firmware so I'm not sure what to do anymore.
2019-4-14
Syaz217
Brunei
Anyone?  This has been happening quite often now.
2019-4-17
vanzyl
South Africa
I posted on 4-21 in new thread about the same issue - lots of views but absolutely no reply.  Seems this is a general issue with OP.  Gimbal does start routine but screen stays blank - tried to get another OP in UK but none of the Argos stores had any stock so I had to make do with a osmo mobile2, which worked OK for the job.  Now  I need to get the OP fixed - only 4 months old!!  I did try to plug into phone but does not connect to Mimo app.  it is as if there is no comms at all.
2019-5-17
mobiteddy
Israel
DJI, sometimes screen flashes or glitches, sometimes black, sometimes partial, sometimes works.
https://drive.google.com/open?id=1TC4RbDErluQ_qACCRgfv2EASCy_VEpc2
2019-6-30
mobiteddy
Israel
mobiteddy Posted at 6-30 03:41
https://www.youtube.com/watch?v=YwRLaChVTco
2019-6-30
mobiteddy
Israel
mobiteddy Posted at 6-30 06:07
So everyone knows, DJI seems good at responding thru facebook messenger, and I'm told that their tech people will be looking at the video I posted above.  I didn't know google drive would be such a hassle with viewing permissions, so the yt link seems to work fine, for anyone here who is wondering what's going on with the screen.
2019-6-30
fansa965d10e
Syaz217 Posted at 4-17 03:59
Did you get this sorted ?
2019-7-23
Jeff.tang.jf
Flight distance : 74928 ft
Switzerland
Anyone solved this yet? I'm having same issue
2019-8-8
xobin
Mexico
Same issue. Sometimes it would resume after turning on and off a few times. However, as of this moment, it won't work anymore; I get a black lit-up screen. (doesn't charge battery, green indicator light doesn't work, camera functions don't work besides the power button)
2019-8-27
johannessutedja\
Indonesia
I also experienced the same problem, can you give me input
2019-10-22
bartourist
Switzerland
[url]Ok, guys, I`m getting quite ANGRY right now. I`ve just got my DJI Osmo Pocket today. I`ve not managed to capture even one sequence. I`ve installed the latest update and this problem with the black screen occurs and the camera doesn`t work AT ALL!  Not to mention, I`ve also recently bought the DJI Osmo Action... it was supposed to be water-resistant to 11m without the waterproof case, it wasn`t. First attempt to jump into the water with it (5ft deep!), aaaand it doesn`t work anymore. I mean COME ON guys!  Two out of two, your products have failed so hard so far! And it`s not just me! I read all these comments in FAQ and I just get more mad! What`s wrong with You?!?!  I`m spending now time on my day off to write this complaint, then I`ll have to go to the store and return ANOTHER of your devices and wait for the extra 3 weeks for the response and MAYBE I`ll get my money back !! This is NOT the quality that I expected when I decided to buy your products ! ! I can send You the link to the video I`ve recorded so You can see the great performance of your DJI Osmo Pocket.
2019-12-3
Kelvintat
Iceland
xobin Posted at 2019-8-27 22:36
hi there, I'm facing the same issue just about few days ago... now i can't even turn on my osmo pocket...
do you how know to fix it? or you just send back for an exchange?
2020-2-2
djiuser_jqyVRqOn8Fwn
New Zealand
My first osmo pocket overheated in the water proof case. I could hardly hold it, it  was so hot. I have just received the replacement under warrenty and this one dosnt work either. The gimble starts but no screen and no power on led. So looks like another $40,00 to return this one. I wonder if the third one will work or if I have to send that one back too. NOT HAPPY.
2020-2-22
LTrain
Flight distance : 91919 ft
My DJI Osmo pocket does the same thing. I called customer service a few months ago and they said it was the memory card. But that doesn't seem to be the case now. And I'm seeing lots of people with the same problem. Is this in inherent design flaw?
2020-5-2
Shang Alf
Vietnam
this piece of junk work randomly black screen also ...  hey DJI are you trying your overpriced product before selling them .. ?
2020-5-23
cafeinbed
Flight distance : 1814918 ft
same problem, did you get it fixed?
2020-9-13
cafeinbed
2020-9-13
djiuser_SyP5PrQqlPqv
Kenya
Syaz217 Posted at 2019-4-14 05:47
Hey...did you ever get to solve this problem? I just got mine and it's been powering on quite well with the display coming up well then all of a sudden it powers on but the display with the logo don't show.Just a dark screen.
2020-11-30
djiuser_ODHQzLFxTN0Y
robomaniac Posted at 2019-4-14 13:30
Thanks, tried that several times without success.
2020-12-27
James Rosca
Philippines
Weird I just remove the sd card and tried to charge the dji pocket now don’t know if it charging and I can’t turn on just experiencing red blinking light when I try to turn it on. Won’t turn on as well. I just charge last Saturday and used it yesterday
2021-4-5
Saveitforparts
I just got a new old stock Osmo Pocket and am experiencing the same issue, nothing on the screen at the back. This is AFTER I replaced the dead battery (massive pain thanks to the horrific design), disabled Android security to install the outdated Mimo app (which isn't on Google Play), upgraded the firmware, and tried different memory cards. From the lack of meaningful reply by DJI in this thread, it sounds like a common problem and they've abandoned this product completely. I assume they're hoping everyone throws them out and buys whatever the new version is.
I bought the Osmo Pocket on a whim and am glad I didn't pay much for it. I can't think of a worse "feature" for an "action" camera than the dangling-off-your-phone USB nonsense. The app itself is laggy even on a modern phone. The microphones placed in the handle with advice to "not block them" is idiotic. Nothing about this product seems to have been thought through beyond "lets stick a drone head on a handle".
I have one of their drones and it's fantastic. I think they should have stuck to drones instead of this failed experiment.
2021-12-18
Curt1591
Thailand
"From the lack of meaningful reply by DJI in this thread, it sounds like a common problem"
It's quite common to those who post this problem on this thread. However, there are thousands that haven't had this issue.
I think you might be better off sticking to drones ...
2021-12-20
