Lysak2003
Flight distance : 500052 ft
Ukraine
There is a rule of 180 degree. For better representation of moving objects you should set your shatter speed us double of frame rate. As Spark shoots with 30 fps it means the shutter speed should be set on 1/60. But! In bright sunny day you need the ND Filter to reduce amount of light on the sensor of camera. Generally you better set the shatter speed in way when your exposure is equal to 0,0. |
