New Mavic 2 Pro/Zoom Firmware Released (2019.01.24)
12345Next >
32693 181 2019-1-24
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2019.01.24
  • Aircraft Firmware: v01.00.03.00
  • DJI GO 4 App iOS: v4.3.12
  • DJI GO 4 App Android: v4.3.12
What’s New?
  • Added Waypoints (requires DJI GO 4 v4.3.12 or later).
  • Enabled Lateral Vision Systems for Timelapse (see Mavic 2 Pro/Zoom User Manual for more information about obstacle sensing).
  • Increased the altitude accuracy of Waypoints in Hyperlapse. When using Task Library to repeat a flight, make sure the takeoff altitude is the same.
  • Fixed issue: the remote controller’s operating time was shortened when used with some mobile devices.
  • Fixed issue: could not open Sphere panorama photos in Facebook.
  • Fixed issue: the Intelligent Flight Battery could not be charged when the environment temperature was between 5° and 10° C.
Notes:
  • Restart the aircraft and remote controller after the update is complete.
  • Please note that update may reset various main controller settings, such as the RTH altitude and the maximum flight distance, to default settings. Before the update, take note of your preferred DJI GO 4 settings, and readjust them after the update.
  • If the update fails, restart aircraft, remote controller, and DJI GO 4 or DJI Assistant 2 for Mavic, and retry.
2019-1-24
Woe
Flight distance : 4129268 ft
Thanks for sharing. Time to update
2019-1-24
Giammi
Flight distance : 847795 ft
How do the waypoints work? Will they allow to set the camera orientation as well? Thank you!
2019-1-24
IcannotThinkOfAName
Flight distance : 623432 ft
Finally, waypoints are here!
2019-1-24
Mojstr
Flight distance : 173465 ft
Slovenia
Hi!
I there is no new version of DJI Go 4 app, i have the version 4.3.11 on Samsung s8. When will the new version be released?
I updated the drone and remote and I don't have waypoints
2019-1-24
Luca Rubino
Flight distance : 711512 ft
How waypoints work?
2019-1-24
ScanDrone
Flight distance : 1026260 ft
Just successfully updated the f/w of both AC and RC using DJI GO 4.3.12 on iPad Pro (iOS 12.1.1). It went without any issues and took about 15 min in all (222 MB).
Been waiting since M2 came out to see what Waypoints 2.0 would look like. It may be that I'm missing something, but it feels pretty weak.
You will find Waypoints with all the other Intelligent Flight Modes, and it's easy to select a Waypoint and mark a POI. You can also save it to the Task Library and load it for future flights. So far so good.
But I struggle to edit anything, it's so easy to add a new waypoint etc instead of editing it. And if you add 1 of mistake, I have not found how to delete that single one, but have to remove everything and start from scratch (or load a saved task).
So my two questions for anyone that has figured it out; 1) how to edit a POI and 2) how to delete a single object (WP or POI)?
Until I figure these things out I think I will stick to Litchi.
Unfortunately it's raining today in Orlando, so no fly opportunity.
EDIT: Found the answers to my questions in the video in post #11. Still struggle some to hit the POI to edit it, but it may be me having "fat fingers" ;)
2019-1-24
ScanDrone
I should add, it doesn't  look like you need the AC/RC being connected to create and save tasks etc, but can do it offline
EDIT: Looks like you have to be connected initially, but after starting Waypoints in DJI GO you can disconnect the AC/RC
2019-1-24
ScanDrone
Mojstr Posted at 1-24 06:40
Hi!
Sorry but I don't have an Android, but for iOS, 4.3.12 is available as of yesterday. And if I understand it correct .12 will bring Waypoints.
2019-1-24
jpap
Flight distance : 1780679 ft
Greece
Thank you DJI! I can't wait to test the new Waypoints 2.0 feature.
Every new feature you add is welcome!
Did anybody had the chance to check if the dynamic homepoint bug for the ios app is resolved?
2019-1-24
ScanDrone
Found this Youtube video about WP 2.0:
2019-1-24
DarthSLR
Flight distance : 1846716 ft
Great! Updated iOS apps on both phone and tablet, will update the drone/batteries tonight after work...
2019-1-24
DarthSLR
ScanDrone Posted at 1-24 07:22
Found this Youtube video about WP 2.0: https://www.youtube.com/watch?v=S1a7wTrAjOE
Thanks for finding and sharing!
2019-1-24
Suren
Flight distance : 13425892 ft
South Africa
Yippee, about time, those that have updated lets us know how it flies
2019-1-24
TrippleDelta
Flight distance : 2228182 ft
Belgium
No waypoints after update.
Edit: Found it
2019-1-24
bikoo
Flight distance : 1534987 ft
United Arab Emirates
update is done ( Drone & RC & batteries ) will test it tomorrow, but for Android still no update on the google store so no waypoint only the IOS is get the update.
2019-1-24
Suren
South Africa
Update done, waypoints are very easy to set up update takes around 10 to 15 minutes to complete, this update is also for the batteries so ensure you update all your batteries as well by switching off drone putting in new battery and restarting the go4 app it will ask to slide to update battery. small test and seems fine. will test properly this weekend
2019-1-24
GlynH
Flight distance : 1762336 ft
Maybe DJI might think about adding a How To Update Video using the Smart Controller?
The reason I mention this is because my Smart Controller sees the firmware update but when I go to download it tells me I am not connected.
This despite it being able to compare revisions with the server in the first instance, being able to go to the DJI homepage and browse the web using the built-in Lightning browser and my Wi-Fi settings telling me I am connected, with an excellent signal strength of 54Mbps on 5GHz!
And yes I do have more than 50% battery in both aircraft & controller.
What gives?
-=Glyn=-
2019-1-24
callaway2288
Way to go DJI!! Thank you for the update!
2019-1-24
A CW
Flight distance : 13838848 ft
There it is thanks for the notification
2019-1-24
Roger1167
Flight distance : 1510728 ft
Thanks DJI.
2019-1-24
WRHershey
Flight distance : 116043 ft
Great!!! Now just 1 more month and users that paid $1000 for the Crystal Sky monitor MIGHT get the update....Yeaaaaa
2019-1-24
Brentjuh
Flight distance : 115728 ft
I dont see waypoints on android. Still have to wait i guess
2019-1-24
Simk1n
Flight distance : 200896 ft
Norway
So with waypoint 2.0 you can pre enter a route and let the drone fly it?
With the old waypoint you actually had to fly the route and save each waypoint, and the you could let the drone fly it?
2019-1-24
HereForTheBeer
Flight distance : 5381368 ft
One of these fixes been a complaint with Mavic Air for entire life of the product and yet mavic 2 gets an update to correct it within no time.  Corrected issue where some devices reduces the remotes operating time.
Could DJI legit listen to their customers..?
RIP Mavic Air.   I officially regret investing in you....
2019-1-24
Paul Atkin
Flight distance : 36962 ft
Hi, i do not see last dji go 4 update .12 on Android 9 on pixel 2 phone. Pls clarify availability.
2019-1-24
mnix
Flight distance : 3865869 ft
Yay, an aircraft firmware update that installed without 27 retries to download it!
Still had to use Assistant because GO said "internet disconnected" but I can live with that.
Also noted that a USB connection to the aircraft now provides access to both the internal storage and SD card.
An interesting thing to note... on my Linux laptop, I use a Windows 10 virtual machine to run Assistant (mostly works well, but occasionally has USB issues)...
What I noticed after the 0300 update is that in addition to the USB drives for internal and SD storage, Linux detects a USB network interface when I plug in the drone!
I wonder what neat new feature they are testing but not telling us about yet :-)  (or is it just a bug?)
2019-1-24
combers
Flight distance : 334652 ft
New Zealand
Paul Atkin Posted at 1-24 15:59
If it helps, I have updated both my android phone and android tablet today.  On phone, there is no new waypoints feature. But on the tablet there is.  Hopefully the waypoints will trickle down to android phones soon.  In the meantime, i will use my android tablet.
2019-1-24
combers
New Zealand
combers Posted at 1-24 21:16
update: it has just appeared on my phone too... that's fast trickle down
2019-1-24
djiuser_y5m1I7Jep6p2
Flight distance : 9045 ft
When comes the android version?
2019-1-25
akozc
Flight distance : 2019951 ft
Macao
Give few hours , should be on the way
2019-1-25
akozc
Macao
Fixed issue: the remote controller’s operating time was shortened when used with some mobile devices.  Dream come true
2019-1-25
mnliew
Singapore
I can't update firmware and the Gimbal is not working
2019-1-25
mnliew
Singapore
got my Mavic yesterday
2019-1-25
mnliew
Singapore
It will not activate at Start up and the remote control can update firmware even using the DJI assistant app on my laptop.
have wrote in to DJI support with the recommendations and comfirmation for online support I need a replacement.
I am rather disappointed with such inccident could take place , Drone Dead On Arrival.
I was really excited and wanted to Fly it today but was really disappointed with this inccident.
2019-1-25
akozc
Macao
I can say this another milestone update specially waypoint
let see how it  works?
I am also so happy to see now android phones will not be charged by the controller. yeayyyyyyy
2019-1-25
fans370d448f
Flight distance : 252073 ft
Taiwan
I have not seen any update for my Note 8 yet? DJI Go 4 still is 4.3.11 on Play store.
2019-1-25
saviour
Flight distance : 604203 ft
akozc Posted at 1-25 01:15
Have you already tested the charging thing? I updated my firmware yesterday and didn't notice any change. I simply let the RC on with my phone on it via USB (the bottom port) and it still drained my battery pretty fast. Have to do some actual flight testing though to see if the RC battery survives 3 drone batteries.
2019-1-25
Simk1n
Norway
fans370d448f Posted at 1-25 01:27
Still no new version here either. Galaxy S9+ and LG G7 (Norway)
2019-1-25
akozc
Macao
saviour Posted at 1-25 01:36
android user need to wait 4.12 version and should be released any moment ( in a days or so)  then we can see all these updates.
  the current version of DJI GO 4  v 4.11 does not shows any changes
2019-1-25
12345Next >
