Signal problem
970 6 2019-1-26
stefano64
hi, I would like to ask for help with a problem I have had several times. In fact, the drone often loses the signal by going 1 or 2 kilometers away (but even less sometimes). The other day he lost the signal going to 200 meters altitude. I do not think they are interference since I also have a mavic pro and it has no problem.
2019-1-26
DJI Natalia
HI, we're sorry to hear about the unpleasant experience that you had with your Phantom 4 Pro. May I know if your firmware is updated to the latest version? If yes, can you please try to fly the aircraft in a different place? If the issue persists, please let us know for further help. Thank you.
2019-1-26
JDC93
Flight distance : 1560371 ft
Is this a loss of image transmission signal or the RC signal?
2019-1-26
stefano64
JDC93 Posted at 1-26 12:59
the drone loses both the video signal and the rc signal
2019-1-27
JDC93
stefano64 Posted at 1-27 05:17
Does this happen in other areas as well?
At a particular spot I fly at, I've lost the signal as little as 2 km out, and at the same spot I've been able to fly nearly 5 km out. Entirely dependent on RF noise in the area at that time.
This isn't to say you don't have a hardware issue, but it's something to think about.
2019-1-27
meowmeow888
Flight distance : 212011 ft
I am having the same problem with my P4A+.
2019-1-28
meowmeow888
DJI Natalia Posted at 1-26 11:16
The issue is persisting in my case. I have tried flying at many different locations to see if the issue is due to interference. I get the same problem to some degree no matter where I go.  All of my firmware is up to date.
2019-1-28
