Hi, we're sorry for the inconvenience. Can you please try to restart your Osmo Pocket? If the issue persists, I suggest you try to reset your Osmo pocket. Let see if this will work. Thank you.
Cisse Posted at 2-5 13:01
Same thing here. Lowest screen brightness is not saving after restart or even a reset.
Yes agreed, this has been since the original firmware, the Osmo pocket reverts back to middle setting brightness even when I switch it to the lowest setting. Please fix in a future firmware, thanks!
Hello everyone, we checked and this case is a normal phenomenon. It will go back to its default brightness when you turn it off and on. No worries, we will suggest this feature be optimized to be capable of saving the brightness set. We will forward this to our R&D department for the future update. Thanks for your understanding.
Yes, please do. The expectation is that it remembers your brightness setting like every other device (mobile phones, tablets, laptops, etc.) Thank you.
