patiam
Flight distance : 1118740 ft
@RDC Agritech- (it looks like your avatar is the kanji for "river", is that right?)-
For all the reasons mentioned by @LV_Forestry and myself, as well as others, you are WAY better off posing well-crafted questions to experts in the field, rather than relying on an AI resource. Also as mentioned, both context/specificity and interpretation can be especially fraught when using such a resource. I get that it is convenient to ask a bot a question, but that convenience comes with considerable risk...
Regarding the topic at hand- I tried to address this in my initial reply:
When (and where) to apply offsets, including (but not limited to) the Z offset between the benchmark on the ground and the antenna reference point (ARP) at the top of the pole/tripod is a question with multiple possible answers, but the rule governing all of them is that you account for all offsets ONCE, and ONLY ONCE.
If your workflow involves generating a PPP solution for your base station coordinates to be used later for subsequent drone flights, and the PPP solution is for the point on the ground over which the base station is located (the "benchmark"), then the Z offset will need to be applied to the PPP-generated coordinates when setting up the base station over that benchmark for those later flights.
If, however, the PPP solution DOES NOT represent the benchmark, but rather the ARP (in other words the pole & APC offests were never accounted for duting PPP), then the Z offset DOES NOT need to be accounted for when setting up the base station over that benchmark for those later flights ASSUMING THE EXACT SAME SETUP (antenna, pole height, etc.) is used.
Again, while this is all pretty twitchy stuff, this particular part of it is pretty basic: offsets MUST BE accounted for, but ONLY ONCE.
I hope that makes sense.
