CR125Honda
Flight distance : 491975 ft
Geebax Posted at 2-16 13:53
You do not need cell service for anything when flying aircraft, and it has nothing to do with RTH. The aircraft has its own GPS receiver, and it uses the GPS data to return home.
Maps can be cached while you are at home connected to WiFi, but once in the field, you are out of range of WiFi, and the plus model has no ability to connect via cellular servicves to the internet to obtain map data.
Thanks Geebax,
Not seeing a position on screen had me concerned.
Normally I hear "Home position set" or "Home position has been updated" through the speaker prior to takeoff.
Don't think I got that audible yesterday before flight but cant be 100% sure.
Wasn't quite sure where it might go if I tried RTH.
Whats exactly, is the purpose of caching a map and when is that cached map being used?
