JJB*
Flight distance : 12225059 ft
hallmark007 Posted at 3-8 03:45
I think looking at your log your craft responded to stick movements, this can be seen as you raise craft, you were trying to continue to raise craft @ 16ft , but it is programmed to not go above 16ft in when you take off in Atti mode, it looks like pretty soon after this your craft took off and crashed , and motor warnings and compass warnings are a direct result of craft crashing, you can see in your log changes in altitude measurements as the bottom of your craft is no longer facing the ground, when this occurs we see more and more motor obstruction warnings, these warnings almost always come when craft has crashed, I’m guessing here because no pictures that a tree was involved , so craft may well be moving around in the tree after crash.
I could be wrong and it could be a malfunction of the craft only dji can confirm this .
Agree with you if there was a tree or something else was involved in his flight.
OP did not say much about this flight....
But, OP increased height to the ATTI height limit, lowered again and than the high pitch and roll angles were there....so if the go up and down movement was at one spot, no tree i guess....
But it it hit something, yes than ofcourse all the motor errors etc because of a crash.
Maby the OP can tell us what really happend.
cheers
JJB |
