KlooGee
Flight distance : 16783757 ft
Sorry to hear of your loss. I would offer to help by looking at your logs, but unfortunately it sounds like that won't be feasible with the app crashing. As some have mentioned here, there is a sizable percentage of DJI flyers that use Android devices very successfully. I'm personally an iOS guy, so my only DJI experience with Androids are with their CrystalSky and Smart Controller.
I know you say you've used multiple devices with all the same problem. Which devices have you used? Also, many times with crashes (not just Android, but iOS and Windows), it can have just as much (or even more) to do with the other apps that are installed and running on the device as it is with the actual app you are using itself. Have you tried with a clean device with only minimal other apps installed?
Unfortunately, none of my questions and comments will do anything to help you get your lost drone back. Given your description of the events, I think only luck will likely help you with that. However, if you would like the community here to try to assist, do as the others have mentioned, and upload whatever logs you do have and then paste the resulting URL(s) here. I'm sure many will be willing to have a look to see if there is anything useful. https://www.phantomhelp.com/logviewer/upload/
I would suggest you open a support case with DJI (https://dji.com/support), however, given your description, I highly doubt they will likely be able to provide you with any answers or a warranty replacement.
A couple suggestions for the future when you get a new drone...- Try to keep your drone in Visual Line of Sight. Getting your drone out of sight exponentially increases your risks if something out of the ordinary (like an app crash) were to happen. When the drone is beyond visual line of sight and something goes awry, it is very difficult (if not impossible) to know which way to steer the drone to be able to bring it back home. If you can clearly see the drone, you can easily see what stick inputs do and be able to bring it back home. This is the reason most countries have regulations around VLOS. I think many of us may be guilty of pushing these boundaries. However, if you do so, you just have to understand you are exponentially increasing the risks of a negative outcome.
- In high wind situations, try to plan your flight to be able to fly upwind instead of downwind. Again, the reason for this is if something out of the ordinary happens (app crash, ATTI mode, etc), the drone is more likely to be pushed back to you rather than away from you.
Best of luck moving forward! I hope you are able to be back up and flying again soon!
