Lysak2003
Flight distance : 500052 ft
Ukraine
Hello! I regularly fly in different patrt of my city (Odessa, Ukraine) that is quite large and overpeopled. I fly in the business, industrial, histirical, recreational districts and suburb, and can say that only places with narrow free spaces, such as lane with tall building on the both sides of the road, or small close squares, could cause you troubles, the main of which is lack of amount satellitrs. In this case you should find open space near here, take off and increase altitude higher than surroundings. Have to notice, that I fly in FCC and always keep the drone in VLOS. Also I hardly ever fly in Sport in the city. Before you fly should estimate the height of the tallest building in the location and set it in RTH settings. Always keep in mind that height when you do backward and side movement, you can simply don't spot an obstacle when your mind busy with filming. It can be very helpful to have a partner with you.
If you lose VLOS, use the map in the left down corner. |
