DJI Stephen
Hello and good day xok. Thank you for reaching out and for the inquiry. Upon checking the mobile device Samsung tab A 2018 10.5'. I am sorry to say that the mobile device is still not recommended for your DJI Mavic Air as of the moment. Actually, there is a possibility that the Samsung tab A 2018 10.5' will work, however, since it's not yet optimized with the DJI Mavic Air and with the DJI Go 4 application we cannot guaranteed the stability of the Samsung tab A 2018 10.5' when in use with the said device and with the said application and if this will work all the time while using the specific device. We highly suggest you use the compatible device that was listed on the recommended mobile device list below to avoid any inconvenience and any problem. Thank you.
