Lamplighter55
Flight distance : 538596 ft
Sometimes if its quite windy the gimbal can do a sudden corrective move when its near to its limits. This though looks like a frame buffering issue - where the data from the camera for one frame has been flushed due to a timing issue - but the codec still integrates the preceding and following frames - creating a motion blurred 'look' (particularly in the first clip) In the second clip a partial frame has been encoded which is why you see a vertical shift with blur - some of the frame data is missing. Worth checking your SD card(s) are able to handle the data rate coming from the drone so called true 4K video rates. Also check if your clips are generally running over the 4096mb file size limit - usually its not a problem - but switching files as the recording continues will put some lag in the system. |
