Mitch72
Flight distance : 69213 ft
A J Posted at 4-29 08:12
Great shot and glad you recovered the drone. Unfortunately, the MP1 has a fixed lens camera so it will probably be a case of having to raise a ticket with DJI and return the drone for a replacement camera and probably gimbal unit.
Thanks AJ..... and yes you are correct about the camera lens, it is an all in one unit, straight forward enough to swap out myself and probably a lot cheaper than sending it off for DJI to do. Everything else on the bird is fine, not even a scratch to the shell, no distortion, she hovers perfectly, the Gimbal works as it should, to be fair you can't see the crack when viewing the live feed from the drone, so at the moment no real hurry to spend lots of money... Especially don't want to break the bank if they are going to bring some ridiculous drone laws in for the UK... They are trying to find a way of implementing something they call Fins? where you would have to apply to fly in a certain area days prior and a strong possibility that they might even charge you for the pleasure, in which case I would prolly sell up in any event lol. |
