Guille_Meinero
Argentina
patiam Posted at 3-13 14:40
Your Method A is my Method 2 from this post (although I wasn't sure you could PPP D-RTK 2 data). What do you put for antenna type if it is asked for? Pretty sure neither RTX nor OPUS has it as an option.
Your method B, using the D-RTK-2 location as a GCP can work, but in the context of Slot Tech's question about PPK'ing his flight data using the D-RTK 2 data is not relevant.
gonna try to upload a very simple step-by-step to ppk drtk2. Not perfect, it just works to me.
Method B... ok, maybe i didn’t understand exactly the scenario that Slot Tech's descript... what im trying to say is... if you flown with DRTK2, no matter is in a known -precise- point or not.... you can PPK drtk2 files (ok, these files NEED to be long enough)
And this takes me to a variant or method C that i didn’t describes b/c i was busy (and sure, as you guess, this is not my natural language) but I use it a LOT (when don’t have cell phone):
1) DRTK2 anywhere, FLY (high precision, low accuracy). Take note of the DRTK2 position, this will be POINT A of the correction vector.
2) Process with drone’s data as usual, you will get ortho and/or DTM as your input (high precision, low accuracy)
3) PPK DRTK2 file, this will give you point B (between 2 or 3 meters)
4) Move your ortho/dtm as the vector
