Hi all.
After succesfully using for almost 2 years a Phantom 4 Pro for Surveying / Mapping purposes, I've decided to purchase a Phantom 4 RTK;
- Obviously, like so many others in here and in other relevant forums, even though I eventually found out a workflow to incorporate my country's geoid and coordinates, I am still having that 20cm difference in Elevations (Ortho Heights). I have managed to extract automatically all the exif data of the photos in a csv file, hoping that I will be able to substract that 19.2cm value I've been reading and then test some more but it's only to be found in the corresponding MRK file. The $1000000 question; Has anyone figured it out?
- My second problem has to do with the camera settings; Apart from not being able to acquire the photos in raw format I can' t seem to find a way to manually input the camera settings I want eg steady ISO, Shutter Speed & F-stop. Once the bird is in the air, my settings are forgotten and camera is set to auto. These settings are critical for sharp photos and many matches in the alignment procedure.
I must point out that I have the latest settings in both controller and drone (2.01 excluded).
Thanks.
