Charissa
Flight distance : 689334 ft
South Africa
Will work in Auto, but the better way to use filters is to set your shutter speed, 24fps, then to 50ss, keep your ISO as low as possible, and then fit the filter that would let you use those two settings without changing.
If you don,t want to spend time with filters on, off etc, then yes, get a good CPL and shoot everything with it. I do this often. CPL on Air is always on, and only change filters if needed.
BUT, do remember, that although Auto can give good quality, it can still wash out your highlights CPL or not.
For the best quality, put some effort into it, and shoot manual with filters as needed, and changing settings on the fly. My 2 cents worth, others might dis agree.
