EnricoBrun
Flight distance : 917087 ft
Yamanote Posted at 5-19 09:53
Enrico, I get you even through the translator.
Normally, in the camera world I am coming from, stopping down your lens to apertures like f8 to f11 will reduce corner softness. However, with the Mavic 2 Pro, at these "high" values the diffraction sets in, so it is better to stay in the range of f4 - f5.6 otherwise the whole image will get more blurred.
Your shot of the canola (awesome by the way) is somehow typical that corner softness is not always a bad thing. But the focus area is different (and to be expected to drift in your shot) as in a 90 ° down image. Although most likely like a hyperbole, the edges should be at least soft equally but not differently. This is why I suspect some misalignment in hardware with the sensor, lens or gimbal.
the photo of the asphalt seems to me seems homogeneous, much more than the first photos you posted, I think the real problem would be seen even in this your last photo
PS : Have you looked with a magnifying glass if the lens sensor is centered? some users saw him visibly decentralized .. |
