Jackson
I have discovered an issue relating the video feed to the GPS acquisition. I have modded the inside of the shell to increase my GPS receptivity. Before each flight I have confirmed that there are a minimum of (10) satellites. After compass calibration the Vision App confirms all satellites have been captured (indicated by blue on the screen). The moment I press the video record button, I lose all satellites - blue turns to gray and the number drops dramatically, even to zero at times. As soon as I turn off the record, all satellites come back - blue and number increases to previous count. I can take photos without issue. I have heard slight grumblings about this on other forums.
- Can anyone please confirm my suspicions that the video feed may be interrupting the GPS connection?
- If this is in fact the case, are there any work arounds? Video capture is the primary reason this was purchased for.
- If there is not a relationship between the two, can anyone please offer some guidance?
Thank you in advance for your time with this.
