Fishycomics
djiuser_cOXi5vzMv8Lu Posted at 3-5 21:00
Got my Osmo Action today activated and latest firm update was complete too. Rocksteady is not seen on the upper right screen is there a specific mode it will work? 4K is only available in HDR mode which has only 30;25;24 fps and even it this mode Rocksteady is not seen in the menu. On a different problem Osmo Action keeps shutting off warning LCD is very hot even
Please turn on and make sure you are on just video mode, not HDR mode. 4K24,25,30,48,60 Rocksteady will work that is 16:9 Aspect ratio. on HDR it is written rocksteady disabled in HDR mode.
go into Preference and make sure the Temp threshold stays on at High not low, that is a temp sensor of the camera, at 100 degrees it will turn off the screen, overheated, and then the camera if it really gets to hot, high the sensor is set at say 125 degrees just an example temp threshold is camera temperature |
