HELP dji mavic pro records over previous files
242 4 2019-5-26
H5 Adventures
Flight distance : 913661 ft
Japan
I have lost quite a few files/recordings because my mavic pro records over previous files whenever I change the battery.  I've tried a forum search as well as google without any helpful results; so I'm not sure if anyone else is having this issue.  Can anyone help with a way to work around this issue?  TIA
2019-5-26
G_Sig
Flight distance : 5864754 ft
Iceland
What settings are used in File index mode?
2019-5-26
Suren
Flight distance : 7372372 ft
South Africa
Have you checked the available space left in your SD Card - recording in 4k can eat up space very quickly.
2019-5-26
H5 Adventures
Japan
G_Sig Posted at 5-26 07:35
[view_image]
It was on reset, that must have been it.   Thank you
2019-5-26
DJI Paladin
Super Moderator
Flight distance : 318 ft
Hi H5 Adventures, sorry for the trouble that it caused and I'm glad that everything is sorted out. As mentioned on post #2, you can use the File Index Mode option.
For the File Index options:
1.Reset
2.Continuous
After you have empty (or delete) all the photos/videos (file 001,002,003) in the SD card, under the "Reset" mode, the new created files will be named from 001.
If you chose the "Continuous" mode, the new created files will be named from 004 (after the deleted file 003).
Should you have other concern, please feel free to contact us. Thanks for choosing DJI!
2019-5-28
