Compass calibration rotation direction matter?
AntDX316
Flight distance : 3394731 ft
In the video he says counter-clockwise but I've been doing it clockwise all the time and these drones always ask for a compass calibration.  Is it because I'm rotating the wrong way?
2019-6-2
Aardvark
Flight distance : 384432 ft
Have a look at my answer to your other question
HERE
All the answers to most of your questions are in the Manual here
Perhaps you should have a rest from taking photos and read that through a couple of times while your unit is getting repared.
2019-6-2
Labroides
Flight distance : 9991457 ft
There is no wrong way.
All that matters is that you expose the compass to a full 360 degrees on each axis.
2019-6-2
DJI Stephen
Hello and good day AntDX316. Thank you for reaching out and for the information you have given. Let me please provide you additional requirements for proper compass calibration. In calibrating the compass of the said drone do not calibrate your compass where there is a chance of strong magnetic interference, such as magnetite, parking structures, or steel reinforcements underground. Do not carry ferromagnetic materials with you during calibration, such as keys or cellular phones. Do not calibrate beside large metal objects. Thank you.
2019-6-2
AntDX316
DJI Stephen Posted at 6-2 07:48
I know but should all compass calibration be done CCW?
2019-6-2
Aardvark
AntDX316 Posted at 6-2 11:10
Post number 4 answers your question.
2019-6-2
AntDX316
Aardvark Posted at 6-2 11:30
I know but I was looking for a DJI answer from the engineers hopefully.  Perhaps doing CCW and far away from the controller would make it not keep asking for a calibration.  Maybe the controller gives off an interference.
2019-6-2
Aardvark
AntDX316 Posted at 6-2 11:49
Your second compass is faulty, unless you've had unit replaced, almost certainly that is why it will keep asking for calibration.
Although the unit will function with one device, under normal circumstances it would still expect to see two compass'. If I were you I would make a claim under the warranty if it is a new unit. From what I've seen it's DJI that cover the warranty themselves and not the dealer. And it should be a fairly straight forward no cost to you process if you're entitled to claim.
In fact you should be demanding a replacement from the dealer.
One way to prove, or disprove your theory would be to try it, it takes two minutes to calibrate the compass.
2019-6-2
Geebax
You won't get a reply from the DJI 'Engineers', they do not appear on this forum. And your aircraft has a missing compass, get that repaired before you do anything else.
2019-6-2
Air/America
When you calibrate, don't have anything metal in your pockets, like your cell phone or your glock.
2019-6-2
AntDX316
Aardvark Posted at 6-2 13:09
My compasses are not faulty.  It doesn't ask me all the time but in New Jersey, it's pretty dense w/ a lot of underground power lines.  Probably, they also metal the ground and put dirt in it so the fields stay level.  They also probably use metal in the parking lots to keep that level too.  Also to keep the buildings level over time.
2019-6-2
Aardvark
AntDX316 Posted at 6-2 15:02
That's odd it looks faulty to me :-
https://forum.dji.com/forum.php? ... 193&pid=1867483
2019-6-2
AntDX316
Aardvark Posted at 6-2 15:24
https://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=190193&pid=1867483
That thread has to be deleted.  I got a new drone with everything swapped.
2019-6-2
Aardvark
AntDX316 Posted at 6-2 15:30
That was quick, I'm surprised you never mentioned it.
So what do your compass readings look like now, better I hope ?
2019-6-2
AntDX316
Aardvark Posted at 6-2 15:35
Yeah, single and double digits.  RTH is also solid on all drones.  If it's above the RTH it just flies back at that height.  If it's lower.  It goes up to it then flies back.  This is when RTH is called but if it loses controller signal it seems, the Mavic 2 Zoom at least when I was flying around the Revel building in Atlantic City and lost signal Completely w/o warning, it flies back the original path I think.  I caught it and manual controlled it but looking at the video it seems that is was happens.  Hopefully, that happened and it just didn't fly that direction and would continue forever if I had no video feed back.
2019-6-2
