MccloudSpark
Flight distance : 27562 ft
I use a Polar Pro set. The polarizer (PL) filter is helpful to reduce sun glare reflecting off of water or other shiny objects. The purpose of the other filters (neutral density or ND) is to reduce bright light so you can better attempt to set a 60 shutter speed (30 fps x 2 for the Spark). This produces a decent amount of motion blur. The filter that allows you to set the correct Shutter Speed (60) while achieving a nicely illuminated image is perfect.
General thinking is:
ND 4 - sunset/sunrise
ND 8 - cloudy
ND16 - bright day, shooting toward a bright light source
ND32/64 - very bright day, desert, snow, water
Sorry if you already knew all of that |
