ff22
You can also plug the Smart Controller (SC) into the computer and download files from it (upload, too, if you want). If you've added an sd-card, the SC will show up as two drives. BUT since it is an Android device, you have to specify that you want to allow both charging AND DATA in order for it to show up. If you miss the prompt (easy to do), you can Swipe Down and check Notifications and get the prompt again and select charge/data.
Now, I have occasionally had to force the connection more than once to get the drive(s) to actually show on my windows machine. So I again will Swipe Down force the prompt and try again (and possible again).
Again, this is presuming that you did DOWNLOAD when you viewed the picture/video. You generally have the choice of internal or sd-card. I do use the sd-card. I may be mistaken but I think the only way you get "compiled" panoramas are if you do download to the controller/sd-card. Otherwise, I THINK that you only have the separate images. So when I do a 360 Spherical, I always preview/view and download. Same with other Pans.
