Geebax
tazztone Posted at 7-28 05:54
i think i found the answer in this Thread
a DJI engineer replied: "Unlike 4K 30fps which has square pixels, the 4K 60fps footage is generated from 5.4K RAW with rectangular logical pixels. This technique allows to make full use of the same area of the sensor as that in 4K 30fps mode and keep the full FOV, without sacrificing dynamic range (compared to 4K windowed readout). It is beyond the performance limit of the sensor to readout 5.4K square pixels at a rate of 60fps."
Yes, except that the statement you quote is not pertaining to a Phantom aircraft, most likely to an Inspire, as the Phantom series do not generate 5K RAW files at all. 4K @ 60 fps has always had some problems, it is not the best format to shoot in, you are better of at 4K30.
'don't mistake cropping with scaling/zooming'
No, I am not, but call it what you want, cropping, scaling zooming are all the same basic technique in post-production. They reqire the application to render a new version of the footage, and that can introduce artifacts.
I looked at two of your clips, and taking the one 'DJI_0006_excerpt.mp4' as an example, there is no significant anti-aliasing that I can see in the clip. But it is simply a long still-frame, which indicates it is not camera-original footage, so no real conclusion can be drawn from that evidence. You say it was produced using Avidemux, so yes, it would have had to be re-rendered to produced a longer file of a frozen image.
