Hi, thanks for the inquiry. You may coordinate this situation to the local department in Canada to check the rules and regulations when flying the drone. You may also check our geo-zone map to determine the restricted areas within this particular location. Please refer to the link below. Thank you for continued support.
The DJI Geo Zone map is DANGEROUSLY misleading! It does not show controlled airspace around airports where you must possess an Advanced RPAS licence AND permission from NAV CANADA to fly in that airspace. (RPAS are what drones are called in Canada)
