solentlife
Flight distance : 1087530 ft
Czechia
Can you switch on the battery ?
Is the light flashing all the time or only when you touch the ON / Off button / plug in charger ?
Are you using a DJI original charger ?
How old is the battery ? Is it still under warranty ?
If still under warranty - get it replaced.
If not then I suggest :
1. Switch on battery
2. Plug in charger
3. Leave it alone - do not touch on / off button and keep checking through the day to see if any change.
If that does not work ... then :
2. LEAVE it alone for 5 - 10 minutes
3. DO NOT touch on / off button - plug in charger
4. Leave it alone - do not touch on / off button and keep checking through the day to see if any change.
It may take an hour .. it may take all day ... if it does not sort by end of a day ... then I don't know what else.
