albertr
Duane, thanks! It's very interesting that they departed from STM32 MCU family they use in a big brother. This i.MX CPU is faster with higher clock speed, but why would one need higher clock frequency on a toy car comparing to the real thing??? I think there're must be other reason(s)... maybe it's less expensive? Anyone has any ideas?
Anyways, looks like firmware is not compatible with the big brother, bummer.
Next to the CPU there is a 8-pin SOIC chip that looks like QSPI Flash, however I don't see any RAM chips around. So, without external RAM, this CPU has only 256KB build-in RAM, which means embedded linux is out of questions, but it can possibly run FreeRTOS or MQX RTOS. Does it look like unpopulated soldering pads for SD card slot on the other side of the board?
I think then next logical step would be to probe serial UART port (I concur that "R T G" most likely mean RX, TX, GND pins) to see which bootloader it runs (connect UART first @ 115200/8-N-1), then power up the board. You should see some messages spitted by the bootloader. If we are lucky, it might even run u-boot, and maybe it will be able to boot off the SD CARD (if it can be added).
-albertr
