pbocsak
Flight distance : 2557333 ft
Switzerland
DJI Stephen Posted at 8-9 10:07
Hello and good day üeter. Welcome to DJI Forum and sorry to know what happened to your previous flight with your DJI Phantom 4 Pro. The drone will revert to ATTI mode when GPS signal is weak, or when the compass experiences interference where the Vision System is unavailable. In ATTI mode, the aircraft is easily affected by its surroundings, which may result in horizontal shifting. Also, in this mode, the Vision System and some advanced features are disabled. Therefore, the aircraft cannot position or auto-brake in this mode. Please land in a safe place as soon as possible to avoid hazards. Avoid flying in areas where GPS signal is weak, or in confined spaces and please do no fly closely above reflective surfaces such as water or snow as these terrains may affect the performance of the vision positioning system. The aircraft will otherwise be forced to enter ATTI mode, leading to a potential flight hazard. Please fly the aircraft on a different location where you have a strong GPS signal. Thank you for your understanding and support.
Hi Stephen,
Thank you for your response. I would like to know what exactly has happened. I do understand that sometimes sensors can be affected by the reflection of sunlight in water or snow, and I'm expecting that. However, today was cloudy, so no interference in that sense. I have flown before in that area, and I have never encountered this issue. Have you watched the video? What can you tell about it?
Thank you,
Peter |
