hallmark007
Flight distance : 9827923 ft
JJB* Posted at 8-25 23:37
Nice saying but do some self reflection.
This forum is to help others, i try to explain what happend or could have happend to a drone when it crashes or et lost etc.
So you base your assessment on knowledge , but what knowledge “None” because there was none, except what OP said, but what you tried to do with that was be selective to suit your theory and this is exactly what I did , but the difference is you come along here and tell us what happened with no evidence, I come here and express from my deductions what Could have happened.
I have in earlier post pointed out, there was no evidence in flight log as to any disconnect or any signal to RC being lost, or any attempt by OP to press RTH.
But there was evidence he clearly didn’t know where he was, as you know he said he was nowhere near any buildings, he also said RTH height was set at 150m, enough to cover all obstacles, we know he was flying in a risky environment in sport mode sometimes at heights over 200m.
All of above we found out from the flight log, the OP never alerted us to any of this, instead he told us signal was lost craft went to RTH and he again pressed Rth , it seems according to you that we should accept that signal was lost and Rth initiated “why” because OP told us, but we should not deduct the fact that the only evidence we have was a log that showed no problems, and we should ignore the fact that the OP failed to tell us all he didn’t know where he was , he wasn’t near any buildings etc.
I also don’t believe for a single minute that dji would tell you that craft crashed into a building if they had no proof, it’s always pretty clear around here when similar happens without proof, that dji will make the same statement, we can see no craft malfunction no pilot error and best we can do is offer you 30% discount .
For me the OP was very selective in telling us what happened here, and the fact that he hadn’t a clue where he was leads me to believe that it’s LIKELY he just crashed.
It is also very common in viewing logs of crashes, that the last few seconds are NOT RECORDED, so log can’t prove this didn’t or did happen.
