djiuser_SGtX4I7iJci7
OK, quick update for Rob.
External drive is formatted ExFAT and is happily read by both the RAV and a Mac.
The limitation about the Photos only folder seems about right but need to do a bit more testing. The RAV App happily backs up the contents of the Photos folder on the iPad, via Wi-fi. It also, for some reason offers to back up ‘Contacts’
Whether this will change with IOS13, I have no idea just yet.
Will try to see how quick it transfers 1GB over Wi-fi later.
In terms of use with just an iPad and travelling with the Osmo Pocket it seems to cover the necessary bases. So pop the uSD card in an adapter then into the RAV, plug in USB storage into the RAV and press the transfer button. You can monitor progress using an iPad and also access the files once each one has fully copied across. Personally I’d fill each uSD, back it up to the RAV and stash the uSD away somewhere safe. I wouldn’t copy the stuff off and re-use the card. Not worth the risk given the low cost of decent cards.
RAV battery lasted at least 6 hours as I was messing about backing up the iPad. This includes powering the external M2 SSD (which got quite warm!) |
