ADAM Elements RC Cable
456 4 2019-9-2
D-Rosin
Flight distance : 76135 ft
Is the lightning to USB, is that one USB END into the bottom of the controller? And other end to your cellphone? I use a S7 Samsung
2019-9-2
HereForTheBeer
Flight distance : 5381368 ft
you can use the USB A port on the bottom of the controller to connect up any smart device that runs DJI Go 4. if you use the USB A port however you will need to unplug any other cables connected tot he RC.
additionally you can  use a micro USB to whatever adapter to plug your smart device into the controller on the side
2019-9-2
DJI Stephen
Super Moderator
Hello and good day D-Rosin. Thank you for reaching out. The ADAM Elements RC Cable can be used for connecting your mobile device to the DJI Mavic Pro remote controller. The USB End is plugged into the bottom of the controller and the USB micro end is plugged into your mobile device. The ADAM Elements Remote Control cable is a high-quality cable designed for DJI Mavic Series, and DJI Phantom Series remote controllers, featuring a unique 90° L-connector to reduce stress while providing the best grip for holding. Just a friendly reminder to remove the side cable from the remote control port when using the bottom port of the remote controller. Thank you.
2019-9-2
msinger
Flight distance : 183694 ft
You definitely don't want to buy a Lightning to USB cable if you're using an Android mobile device. Lightning cables can only be used with Apple devices.
2019-9-2
A J
Flight distance : 12810843 ft
You'll want the USB to Micro USB or USB to Type C depending on which android device you intend to use. Lightning is for apple products only
2019-9-8
