Wolferl
Flight distance : 23793 ft
fans2c59cbe5 Posted at 9-8 14:46
Sorry I’m still pretty new with the editing. I’ve just been using iMovie so what you are saying is there’s a way to downscale any footage I get in iMovie to 25 FPS? Thanks for the reply!
Hi,
"downscale" is the wrong word for it (that means a reduction of the resolution of the video, for instance from 1080p to 720p). The more correct term is "frame rate conversion". You need to find a software which does this the best (conversion from 30fps to 25 fps).
It could be a good idea to purely convert the raw footage from the Spark first to 25fps. If result is smooth, next step will be editing with that converted clip (not the raw).
Cheers,
Wolferl |
