DJI OM3 + Filmic Pro?
1234
60200 125 2019-9-21
djiuser_xEhpuGtXOrSY
India
GOOD NEWS....
Now filmic pro is compatible with dji osmo mobile 3 and dji OM 4.
2020-9-30
fansfe82067d
But sadly you can't change the gimbal mode without switching to the DJI Mimo app.  This is due to DJI's odd decision to make mode switching not a hardware button function.  Not the end of the world, but a pity.
2020-10-8
fansfe82067d
I tried it up the park this afternoon and was a bit unimpressed.  The concept of modes means that you have to decide what features you are going to use for the shot, and you may well find that none of the modes contains the set you need.  I plan to work out a better control scheme and suggest it for Filmic - which I doubt whether they will take any interest in.  I guess there are reasons behind the way they've implemented things which aren't apparent to the end user.
2020-10-10
fansfe82067d
fansfe82067d Posted at 10-10 01:22
My suggestion to them is that in all Filmic Pro modes, the joystick should control the gimbal whenever the trigger is held down.  To my mind, that's the simplest way of doing things.   Whether it's technically possible, I don't know.  It works in mode one already but that doesn't mean it would work in the others.
2020-10-10
valhelirc
Dominican Republic
After 2 months testing I've found the best way for me to use it is as follows: 1- Set Til Lock mode in DJI Mimo app. 2- Open FilmicPro and do not connect the Gimbal to retain TiltLock mode. 3- Set the Focus reticle to the big one and don't lock it. 4- Enable manual sliders, set shutter speed to at least double the frame rate value and lock it. Then adjust iso value, lock it and close sliders.  Go ahead! Hit record gimbal button and enjoy it! This way you don't have to worry messing modes as you can control tilt and pan via the joystick and will keep your composition while on moving shots so Tilt will remain locked. Hope this helps.
2020-11-14
Jroberts5483
DJI Stephen Posted at 2019-9-21 09:19
Hello and good day georgemessiah. Thank you for reaching out and for the inquiry. I hope that you will get the best recommendation from our valued DJI members who owns the DJI Osmo Mobile 3 and who are using the Filmic Pro. Just a friendly reminder that we do not recommend using 3rd part applications when operating or using your DJI Osmo Mobile 3 for compatibility and reliability purposes for both the gimbal and of the DJI Mimo application. Thank you.
Lol, 3rd party apps are the only ones that work for us Android users, even though theres a Google Play sticker on the box, kinda misleading
2021-3-2
1234
