Mark The Droner
Flight distance : 2917 ft
There are several variations of the P2, so it's important to describe your AC completely and correctly to avoid confusion as there are significant differences between the models. Since you used a "+", I assume you have a DJI Phantom 2 Vision+.
The binding process is described in the manual which can be found on this site. You'll need the MAC address of the wifi module inside the drone. It's on the sticker on the module inside the drone. If you're lucky, it may be on a sticker on the bottom of the AC, but probably not. You can also get it with a wifi analyzer.
Your drone is about five+ years old, so chances are better than even that your wifi module has the "black screen" which means, although you can probably bind it and get telemetry and other info, you won't have FPV. Usually a flash of the bottom board will solve the problem. The procedure is outlined at various online sites including youtube.
Good luck |
