Major bugs with this setup ON THE RONIN S WITH X-T3 RONIN S - VERSION 1.1.2.28
1. If camera is OFF and you turn it on.
a) you lose control of all the camera buttons. (can't change shutter speed / iso dials and all hard buttons do not respond)
b) it turns off the FLOG and forces whatever film emulation you had on it last.
c) auto focus works with a half press - the only positive thing.
d) Camera performace 'boost mode turns off' so after 10 seconds the LCD goes into power saving mode (dims and gets laggy).
e) rec trigger on camera and on gimbal do not trigger recording - so no way to record internally.
2. If you then turn the gimbal off with a double press of the power button:
a) resets the camera back to FLOG (or whatever you had it set to)
b) allows you to use the hard buttons and dials on the camera again.
c) auto focus turns on to (delayed) continious AF. (regardless if you have the front dial set to S or C AF on the camera).
