bobzwik
I tried using the log viewer in Assistant 2, but it didn't seem to work well, and I couldn't get the export feature to work.
I found other posts suggesting to use DatCon open source software.
When you open Assistant 2 and connect the M210, click on "Flight Data". A couple of seconds letter, a Windows Explorer windows opens to the folder DJI FLIGHT LOG (it shows up as drive E:\ on my computer. I can't find this drive if I haven't click the "Flight Data" tab first).
In that folder, find the FLY***.dat log that you want (you can see in their properties when the files were created).
Use DatCon to decode the log. You can choose to decode everything, or you can define when you want to start and end the decoding, and also when you want to have your time = 0.
For the .CSV export, you can choose the logging frequency you want to save.
And there you go!
You might want to know that I've noticed that the M210 time increases faster than the GPS/RTK time (which is retrieved from satellites) |
